12 years agounhosted baremetal boot
I'm tring to boot a baremetal application from uboot. I linked my application with a script like the one in examples (altera-socfpga-hosted.ld) whith following modifications: line 23: GROUP(-lgcc -lc -lcs3 -lcs3hosted -lcs3arm) to GROUP(-lgcc -lc -lcs3 -lcs3unhosted -lcs3arm) and line 28: ram (rwx) : ORIGIN = 0x02000000, LENGTH = 32M ram (rwx) : ORIGIN = 0x01000000, LENGTH = 32M running the application from debugger all works fine. When I try to run the application from u-boot with the following commands: fatload mmc 0:2 0x01000000 myApp.bin go 0x01000000 or go 0x01000040 the command fail with this error: # # Starting application at 0x01000000 ... data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<3ff8223c>] lr : [<01000198>] sp : 3ff4f63c ip : 00000083 fp : 00000000 r10: 00000002 r9 : 00000000 r8 : 3ff4ff60 r7 : 3ffbb8c4 r6 : 01000000 r5 : 3ff505fc r4 : 00000002 r3 : 01000000 r2 : 3ff505fc r1 : 010001d0 r0 : 60000153 Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ... running a readelf in a linux shell the result is: readelf -h myApp.elf ELF Header: Magic: 7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00 Class: ELF32 Data: 2's complement, little endian Version: 1 (current) OS/ABI: UNIX - System V ABI Version: 0 Type: EXEC (Executable file) Machine: ARM Version: 0x1 Entry point address: 0x1000040 Start of program headers: 52 (bytes into file) Start of section headers: 399332 (bytes into file) Flags: 0x5000002, has entry point, Version5 EABI Size of this header: 52 (bytes) Size of program headers: 32 (bytes) Number of program headers: 2 Size of section headers: 40 (bytes) Number of section headers: 20 Section header string table index: 17 What is wrong? Thank you NicolaNo RepliesBe the first to reply
