15 years agoUnderstanding training patterns for Stratix-II deserializer DPA
Hi, I am trying to figure out requirements for Dynamic Phase Alignment (DPA) as implemented by LVDS receiver (non-GXB) in Altera Stratix-II family. The device handbook provides very limited inf...
15 years ago --- Quote Start --- In the last section of the handbook(all the timing numbers) there should be DPA specs. --- Quote End --- There are specs in Chapter 5, but they don't answer my questions. For example, could long run of 10-bit "comma" patterns generated by one of the popular 8b/10b alphabets serve as DPA training sequence when deserialization factor=8 rather than 10? Chapter 5 gives no answer. To the contrary, the spec tables in Chapter 5 introduce yet another concept that I don't understand (and that handbook does not explain) - DPA run length. If there is no good answer to my questions above, may be, somebody here could answer a related question. What happens when DPA is presented with sequence of bits that is guaranteed to have certain density of transitions, for example, >10%, but is totally aperiodic? Does DPA do nothing at all in this case or does it continue to track after timing changes, just less efficiently than with "legal" training sequence?
