16 years agoUnable to use EPCS device_Leaving target processor paused
#!/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd C:/altera/91/quartus/work/firefig...
16 years agoDoes the epcs base address you specify (--base=0x00011000) match the actual one as defined in sopc builder?
Have you programmed that epcs device before with a fpga configuration file? Are you sure it works? Regards
