9 years agoUnable to run different versions of altera libraires
I am new to FPGA simulation.I was given with a qsys file.From this qsys I should generate system & tb and should simulate them. Here i am using quartus 15.1.2.193.Some libraries are getting generated from earlier version of quartus(say 14.0). So whenever I try to simulate them in uvm I am facing this below error. ncsim: *F,NOLWSV: Searching for import subroutine "axi_set_master_end_abstraction_level" in default library libdpi. Unable to load the default library libdpi. I am using ncsim. can anyone help me in clean this errorS?3 Replies
SAME here.
Is this error fixed?? I am facing this issue currently....:confused::confused:
Got the same error, anyone can help ? thanks a lot.
