11 years agoUnable to launch modelsim from quartus
High, can anyone tell me how to launch modelsim form quartus. I am getting following error when i tried to launch it??? how to remove this error???
I use the Quartus II ver. 15.0.0.0 web edition on Linux. When I select "Run simulation tool", display the dialog and can not launch modelsim. - Altera_Forum
the extra slash there might make a different for old version of Quartus II
Are you able to open modelsim executable in C:\altera\13.1\modelsim_ase\win32aloem\modelsim.exe?
Have you actually got ModelSim installed at that location?
--- Quote Start --- You need to add the correct path to Tools>Options>EDA Tool Options. I have C:\altera\14.1\modelsim_ase\win32aloem in ModelSim-Altera. You probably need the same, if you are using the Web edition. --- Quote End --- I have this setting in my quartus... C:\altera\13.1\modelsim_ase\win32aloem I am using web base edition 13.1...I have even read out the manual "Getting Started with Quartus II Simulation Using the ModelSim-Altera Software" but I am receiving the same error - Altera_Forum
