Unable to Generate Valid PAM4 Eye Diagram and BER Measurements on Stratix 10 SI E-Tile Native PHY
- 22 days ago
TTK in Quartus 18.1 Eye Viewer is really old and the newer Quartus would resolved most of the problem. I would advise to use the latest Quartus.
The E-Tile PAM4 link must use true differential TX+/TX− and RX+/RX− signaling; terminating RX− with 50 Ω and applying only 20 mVpp to RX+ is not sufficient for reliable 51-Gbps reception. A locked PLL/CDR does not guarantee valid PAM4 eye separation, so use direct differential SMA loopback first, PRBS13Q/PRBS31Q, initial adaptation with valid traffic, and disable continuous adaptation before BER/Eye Viewer. A full-red heatmap and undefined eye dimensions usually indicate invalid/weak differential data, incorrect mapping/equalization, or a Toolkit issue—not simply insufficient captured bits.
Thanks for the help so far.
I have another doubt regarding the SMA channels on the E-tile:
- My experimental setup uses single-ended signaling. Can I terminate Tx− and Rx− with 50 Ω and proceed using Tx+ and Rx+ only?
- What is the minimum acceptable peak-to-peak voltage level for the Rx input? Does the Rx input need to be differential, or can it operate with a single-ended input?
- We are getting around 500 mVpp on Tx+, which we process through some channel. After this conversion, we are getting approximately 20 mVpp, which we plan to feed into Rx+. Would this voltage level be sufficient for the Rx to reliably detect the signal?
