Unable to Generate Valid PAM4 Eye Diagram and BER Measurements on Stratix 10 SI E-Tile Native PHY
- 2 months ago
TTK in Quartus 18.1 Eye Viewer is really old and the newer Quartus would resolved most of the problem. I would advise to use the latest Quartus.
The E-Tile PAM4 link must use true differential TX+/TX− and RX+/RX− signaling; terminating RX− with 50 Ω and applying only 20 mVpp to RX+ is not sufficient for reliable 51-Gbps reception. A locked PLL/CDR does not guarantee valid PAM4 eye separation, so use direct differential SMA loopback first, PRBS13Q/PRBS31Q, initial adaptation with valid traffic, and disable continuous adaptation before BER/Eye Viewer. A full-red heatmap and undefined eye dimensions usually indicate invalid/weak differential data, incorrect mapping/equalization, or a Toolkit issue—not simply insufficient captured bits.
As suggested, we installed Quartus Prime Pro 24.1. However, we could not find the Transceiver Toolkit (TTK) in the System Console.
Could you please recommend the exact Quartus Prime Pro version that includes both the Transceiver Toolkit and the board example designs for PAM4 operation over the SMA connectors?
Previously, we used Quartus Prime Pro 18.1, which included board example files for PAM4 programming through the SMA interface. However, we were unable to successfully complete the Eye Viewer test, as described in our earlier correspondence.
It's Urgent, kindly respond.
Kind regards.
Just wanted to follow-up. Do you have any further queries on the topic?
