Unable to Generate Valid PAM4 Eye Diagram and BER Measurements on Stratix 10 SI E-Tile Native PHY
- 2 months ago
TTK in Quartus 18.1 Eye Viewer is really old and the newer Quartus would resolved most of the problem. I would advise to use the latest Quartus.
The E-Tile PAM4 link must use true differential TX+/TX− and RX+/RX− signaling; terminating RX− with 50 Ω and applying only 20 mVpp to RX+ is not sufficient for reliable 51-Gbps reception. A locked PLL/CDR does not guarantee valid PAM4 eye separation, so use direct differential SMA loopback first, PRBS13Q/PRBS31Q, initial adaptation with valid traffic, and disable continuous adaptation before BER/Eye Viewer. A full-red heatmap and undefined eye dimensions usually indicate invalid/weak differential data, incorrect mapping/equalization, or a Toolkit issue—not simply insufficient captured bits.
Here are my recommendations:
Step 1 — Upgrade Quartus Prime Pro (Critical)
Quartus 18.1 is 8 years old. PAM4 E-Tile support has received extensive fixes since then. Recommend upgrading to at least Quartus 24.x (or latest). Many PAM4 adaptation, eye viewer, and toolkit fixes were delivered in 19.x–24.x releases.
Step 2 — Use Proper PRBS Pattern for PAM4
The user-defined pattern does NOT exercise all 4 PAM4 voltage levels. This alone can cause "eye could not be detected."
Use PRBS31Q (quaternary/PAM4-aware PRBS) from the Transceiver Toolkit's built-in pattern generator, not a custom pattern. This ensures all 4 symbol levels (0, 1, 2, 3) are properly exercised.
Step 3 — Signal Integrity Check (SMA Cable)
A 50 cm Pasternack PE3CA1035 SMA cable may have excessive insertion loss at 25.5 GHz (PAM4 Nyquist for 51 Gbps). Recommend:
Use the shortest possible cable (< 15 cm) or a calibrated test fixture
Alternatively, test with serial internal loopback (SILB) first to eliminate the cable as a variable
Step 4 — Adaptation Sequence
Run continuous adaptation (not one-time) for PAM4. The adaptation FSM needs to converge VGA/AGC, CTLE, DFE, and IQ timing for all 3 PAM4 eyes.
After enabling continuous adaptation, wait for it to fully converge (observe stable CTLE/DFE tap values in Toolkit) before running Eye Viewer.
Step 5 — TX Pre-emphasis / FIR Settings
For a short SMA loopback, start with:
Pre-tap = 0, Main tap = max (e.g., 55), Post-tap = 0
Adjust only if needed after confirming basic link with SILB
Step 6 — Eye Viewer Configuration
Ensure Eye Viewer is set to PAM4 mode (measures top, middle, and bottom eyes)
Let the tool accumulate sufficient bits at each BER point (~10⁸ bits minimum at 51 Gbps before starting eye scan)
Verify CDR lock-to-data is asserted before running Eye Viewer
Step 7 — Verify lock status registers
Before running Eye Viewer, confirm: rx_is_lockedtodata = 1 and rx_pll_locked = 1
If CDR is locked to reference (not data), the eye measurement will fail
Recommended Debug Sequence (Short form for response)
First: Try internal serial loopback with PRBS31Q → confirms transceiver PMA works
If SILB passes: try external loopback with shortest cable available
If short cable passes: troubleshoot with original 50 cm cable (likely too lossy)
- pryngshu4 months ago
As suggested, we installed Quartus Prime Pro 24.1. However, we could not find the Transceiver Toolkit (TTK) in the System Console.
Could you please recommend the exact Quartus Prime Pro version that includes both the Transceiver Toolkit and the board example designs for PAM4 operation over the SMA connectors?
Previously, we used Quartus Prime Pro 18.1, which included board example files for PAM4 programming through the SMA interface. However, we were unable to successfully complete the Eye Viewer test, as described in our earlier correspondence.
It's Urgent, kindly respond.Kind regards.
- Ash_R_Altera3 months ago
Just wanted to follow-up. Do you have any further queries on the topic?
- pryngshu2 months ago
Hi, that issue has been resolved. We are now able to generate PAM4 and NRZ signals and control them through TTK.
However, we observed that when no data is being transmitted on Tx, i.e., when the generator is turned off, a clock-like signal is still present on the Tx output. Could you please let us know what might be causing this?
Additionally, the measured data rate or clock rate are significantly different than the configured/set data rate. Could you please advise on the possible reasons for this discrepancy as well?
I suspect that probably the design is not properly configured to enable the TTK. Please refer the section 10.3 and make sure that the E-tile IP has correct settings enabled.
The latest version of the Quartus is 26.1. Recommend you to choose the latest one.
For the design example, unfortunately there is none for PAM4 native PHY IP.
