16 years agounable to display state transition due to long processing time
i'm trying to work with the FSM viewer on a program that contains only 3 states and all i got is :"unable to display state transition due to long processing time"
i cant figure out what is the problem ?? maybe somone got a clue ?? the program is : LIBRARY ieee; USE ieee.std_logic_1164.all; -- Entity Declaration ENTITY Baud_Rate IS -- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE! PORT ( Ser_Data : IN STD_LOGIC; Reset : IN STD_LOGIC; Clk : IN STD_LOGIC; Baud_Rate_Clk : OUT STD_LOGIC ); -- {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE! END Baud_Rate; -- Architecture Body ARCHITECTURE Baud_Rate_architecture OF Baud_Rate IS TYPE State IS (Initial,First_Bit, Baud_Calc,Jump,Next_Pkg,Sample,Output_Clk); SIGNAL Cur_State : State; BEGIN PROCESS (Clk,Reset,Ser_Data) ------------------------------Initialization Of Variables -------------------------------- VARIABLE Int_Clk: INTEGER RANGE 0 TO 50000 :=0; VARIABLE Ticks_Count : INTEGER RANGE 0 TO 50000 :=0; VARIABLE Bit_Count : INTEGER RANGE 0 TO 50000 :=0; BEGIN IF (Reset='0') THEN Baud_Rate_Clk<='0'; Int_Clk:=0; Ticks_Count:=0; Bit_Count:=0; Cur_State <=Initial; ELSIF ( clk'EVENT AND clk='0') THEN CASE Cur_State IS ------------------ Variable Initializations And 'Start' Acceptence ------------------------- WHEN Initial=> Int_Clk:=0; Ticks_Count:=0; Bit_Count:=0; IF (Ser_Data='0') THEN Cur_State <=First_Bit; else Cur_State <=Initial; END IF; ------------------- First Bit Acceptence ------------------------------------------------ WHEN First_Bit=> Int_Clk:=0; Ticks_Count:=0; Bit_Count:=0; IF (Ser_Data='1') THEN Cur_State <=Baud_Calc; END IF; ---------------------- Baud Rate Calculation ------------------------------------ WHEN Baud_Calc => IF (Ser_Data='1') THEN Int_Clk:=Int_Clk+1; ELSE Ticks_Count:=0; Bit_Count:=0; Cur_State <=Jump; END IF; ---------------------Skips the '31h' ------------------------------------------------------------- WHEN Jump=> IF ( Bit_Count<10) THEN Baud_Rate_Clk<='0'; IF (Ticks_Count < Int_Clk ) THEN Ticks_Count:=Ticks_Count +1; ELSE Bit_Count:=Bit_Count+1; Ticks_Count:=0; END IF; ELSE Cur_state<= Next_Pkg; END IF; ---------------------Recives The Next Package And Test It ---------------------------------------- WHEN Next_Pkg=> Baud_Rate_Clk<='0'; IF (Ser_Data='0') THEN Cur_State<=Sample; Bit_Count:=0; Ticks_Count:=0; Baud_Rate_Clk<='0'; END IF; ---------------------Sample In The Middle Of the Bit ---------------------------------------- WHEN Sample=> IF( Ticks_Count<(Int_Clk/2)) THEN Ticks_Count:=Ticks_Count+1; ELSE Cur_state<=Output_Clk; Bit_Count:=0; Ticks_Count:=0; Baud_Rate_Clk<='0'; Baud_Rate_Clk<='1'; END IF; ---------------------Creating The New Clk for the Reciver Sample ---------------------------------------- WHEN Output_Clk=> IF( Bit_Count<12) THEN IF(Ticks_Count<Int_Clk) THEN Ticks_Count:=Ticks_Count+1; Baud_Rate_Clk<='0'; ELSE Ticks_Count:=0; Bit_Count:= Bit_Count+1; Baud_Rate_Clk<='1'; END IF; ELSE Cur_state<=Next_Pkg; Baud_Rate_Clk<='0'; END IF; WHEN OTHERS=>NULL; END CASE; END IF; END PROCESS; END Baud_Rate_architecture;8 Replies
Is there any new update to this? I have the same problem concerning my 85-state state machine.
i filled , still waiting for an answer...
--- Quote Start --- Hi, did you file a service request ? Kind regards GPK --- Quote End --- I will .... together with the "outdated processes" on the process panel :D Btw, I think Altera has a IP design team, they should've spotted these way earlier. Nvm, I'll report. - Altera_Forum
--- Quote Start --- Cr***y Quartus :D ... even version 9.1SP2, this thing still can't work properly. --- Quote End --- Hi, did you file a service request ? Kind regards GPK - Altera_Forum
its aint working on the 9 addition ....really strange
--- Quote Start --- (this one has more than 3 states , but also on 3 states it aint working ....) --- Quote End --- Hi, I could open your statemachine with Quartus Web 7.0. I looks like that you found a bug in Quartus x.x. You should file a service request. Kind regards GPK - Altera_Forum
