12 years agoUdp\ip tse
I am working with EVM == " Nios II Embedded Evaluation Kit (NEEK), Cyclone® III " I want work under UDP/IP protocol without the need the NicheStack IPv4 and Microc\OS . I want only send a f...
12 years agoStep 1: review the UDP Offload Example
Step 2: make it work on your hardware Step 3: remove from the example the items which you do not want (InterNiche stack, etc.) or you could also just start from scratch and pull in the relevant blocks out of that example, but I believe that may require more labor if you are not very familiar with it already.
