12 years agoUdp\ip tse
I am working with EVM == " Nios II Embedded Evaluation Kit (NEEK), Cyclone® III " I want work under UDP/IP protocol without the need the NicheStack IPv4 and Microc\OS . I want only send a f...
12 years ago --- Quote Start --- Thanks for your request This source example could be used on my EVM BOARD Neek 3C25 without hard effort ? if I will only modify : 1 the to the required Cyclone III . 2 the pin placements assignments to match the NEEK EVM. 3 Compilation . Does they enough to send stream UDP\IP from my EVM (NEEK) to My PC or not , or I must another modification ? Tx again for your cooperation !!!!!! --- Quote End --- P.D. I see UDP Packet Offload Example .pdf I asked on my first request that I do not want to use InterNiche stack so what mean: ............................................." The way to connect with the demo boards over the network is to run a telnet session and login to each boards’telnet server provided by the InterNiche stack.
