12 years agoUdp\ip tse
I am working with EVM == " Nios II Embedded Evaluation Kit (NEEK), Cyclone® III " I want work under UDP/IP protocol without the need the NicheStack IPv4 and Microc\OS . I want only send a f...
12 years agoThanks for your request
This source example could be used on my EVM BOARD Neek 3C25 without hard effort ? if I will only modify : 1 the to the required Cyclone III . 2 the pin placements assignments to match the NEEK EVM. 3 Compilation . Does they enough to send stream UDP\IP from my EVM (NEEK) to My PC or not , or I must another modification ? Tx again for your cooperation !!!!!!
