14 years ago
UDP Offload on DE2-115
Hi guys,
Has anyone been successful in porting the Nios II UDP Offload Example (alterawiki DOT com/wiki/Nios_II_UDP_Offload_Example) to the DE2-115?
I'm not sure what functions to call to initialize the PHY, etc. Do I also need to use uC/OS even if the packets are not handled by NIOS?
    --- Quote Start ---
    Thanks Socrates. I tried to build the software sources using the create-this-app script, but I'm getting these errors:
    In function `udp_demo_init': ...... : undefined reference to `install_menu'
    In function `display-build': ...... : undefined reference to `stooges'
    Any idea what's causing this? I'm using the script that came in the folder.
    --- Quote End ---
    To anyone having this same problem:
    This was caused by permissions in patching the source files. To build this correctly, you need to run Nios II Command Line as administrator and run ./create-this-app.
    Create the same hardware design for Your FPGA, change pins and compile the design. The software will fit as it is not dependent on the hardware.
    --- Quote Start ---
    Hi guys,
    --- Quote End ---
    I have the same questions.:confused:
