14 years agoUDP Offload on DE2-115
Hi guys, Has anyone been successful in porting the Nios II UDP Offload Example (alterawiki DOT com/wiki/Nios_II_UDP_Offload_Example) to the DE2-115? I'm not sure what functions to call to ...
14 years agoCreate the same hardware design for Your FPGA, change pins and compile the design. The software will fit as it is not dependent on the hardware.
