14 years agoUDP Offload on DE2-115
Hi guys, Has anyone been successful in porting the Nios II UDP Offload Example (alterawiki DOT com/wiki/Nios_II_UDP_Offload_Example) to the DE2-115? I'm not sure what functions to call to ...
14 years ago --- Quote Start --- Thanks Socrates. I tried to build the software sources using the create-this-app script, but I'm getting these errors: In function `udp_demo_init': ...... : undefined reference to `install_menu' In function `display-build': ...... : undefined reference to `stooges' Any idea what's causing this? I'm using the script that came in the folder. Thanks --- Quote End --- To anyone having this same problem: This was caused by permissions in patching the source files. To build this correctly, you need to run Nios II Command Line as administrator and run ./create-this-app.
