9 years agoUart without Nios
Hi guy!!
How can I use UART core without NIOS?? (I want to implement a UART port to Cyclone II without NIOS) Qsys has a UART (RS 232 Serial Port). UART has a Avalon Memory Mapped Slave, so I think if I want to use a UART without NIOS I need a Avalon Memory Mapped Master...... Am I correct whit that?.:confused: If I'm correct, Qsys gives me two Avalon MM Master........ avalon-mm master translator and avalon-mm master agent. So, Which should I use?:confused: Regards.2 Replies
Thanks for reply!!
Well, my idea is implement Qsys too, because I've never use it, therefore I want to implement a UART. Thanks for your code. - Altera_Forum
Just code up a UART module. The functionality is pretty simple and it is not difficult to implement exactly what you need.
Or else just cheat and use google: http://www.asic-world.com/examples/verilog/uart.html
