15 years agouart transmitter
Hi there! I need to decode comands and data sended by device. On the one side I have device with clk, dc, cs and data ports, on the other there is cable uart -> usb. I wrote module to g...
15 years agoIt was many years since I used that model. I suggest that you run the testbench and understand the clocking scheme. As I quickly remember, the 16x clk and system clk are different. You may need some sync (e.g. 2 stage reclock) if needed.
Ben Cohen Ben at systemverilog dot us
