15 years agouart transmitter
Hi there! I need to decode comands and data sended by device. On the one side I have device with clk, dc, cs and data ports, on the other there is cable uart -> usb. I wrote module to g...
15 years agoThanks a lot for your answer! :)
As I suppose, data grabing process should be synchronized by clk from device, while data sending should be synchronized by clk form FPGA (proper to get specified baud rate). Am I right? If so, how i can get specified baud rate? Terminal program, which I use at the moment shows only data in sended in packets. Is there any software which show me exactly what's getting from FPGA to PC (i mean bit after bit).
