17 years agouart RS232 communication problem
Hi all, I have cyclone2 dev kit. I tried running uart program given in the Embedded Peripherals pdf but there is no output on the hyperterminal. I have set the baud rate to 9600 and i have changed...
17 years agoThanks for the directions. I get these warnings when I try run in Instruction Set Simulator. Do I need use SOPC builder to correct these.
Please guide me further. Thanks. Warning : SOPC Builder system component led_red is not supported by the simulato r. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component led_green is not supported by the simula tor. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component button_pio is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component switch_pio is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component SEG7_Display is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component sram_0 is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component Audio_0 is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component SD_DAT is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component SD_CMD is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component SD_CLK is not supported by the simulator. Simulation may be incorrect if your software attempts to access it
