17 years agouart RS232 communication problem
Hi all, I have cyclone2 dev kit. I tried running uart program given in the Embedded Peripherals pdf but there is no output on the hyperterminal. I have set the baud rate to 9600 and i have changed...
17 years agosimulator doesn't need any hardware support.
if it doesn't run in simulator , doesn't take i/ps and o/ps there is something absolutely wrong in the way in which you incorporated your UART in the VHDL/verilog project. if the QUARTUSII isn't giving any kind of errors while compiling your project, atleast you can check the warnings to get an idea. I think it is something basic that you are missing out here
