15 years agoUart data ready
Hi all,
I am periodically sending data from LabView to my cycloneIII development kit (bemicro) and I want to check if there is data available to be read in NIOS II. Unfortunately, I have not been able to use the data ready bits, can someone enlighten me on how to do this?! Do I need to use ALT_UART_READ_RDY 0x1 or ALTERA_AVALON_UART_CONTROL_RRDY_MSK (0x80) ? If yes, how am I supposed to do so? Any help would be appreciated! marek16 Replies
Be sure that uart_base matches to your SOPC UART_BASE :
maybe you have changed your sopc (in Quartus SOPC Builder) and you have forgotten to rebuild your "system library" (I don't know the exact name in NIOS > 9.1, perhaps "BSP" :confused:) in NIOS IDE (or SBT or ...) - Altera_Forum
Hi again,
It seems that the foloowing statement does not return the proper status bits. status = IORD_ALTERA_AVALON_UART_STATUS(UART_BASE); Are there any specific functions that can mess with the status bits? Do I need to initialize something in particular for this to work? Any special includes? I would appreciate some help!!! - Altera_Forum
Thanks for the replies. Unfortunately I still didn't get the code to work, the if statement returns remains false... Does anyone have any suggestions?
BTW, it should read: if (status & altera_avalon_uart_status_rrdy_msk) instead ofif (status & altera_avalon_uart_control_rrdy_msk). - Altera_Forum
No, if (status & altera_avalon_uart_control_rrdy_msk) is a good code (fails only if mask=0x0 which doesn't usually happen).
--- Quote Start --- status = IORD_ALTERA_AVALON_UART_STATUS(UART_BASE); if (status & ALTERA_AVALON_UART_CONTROL_RRDY_MSK) { } --- Quote End --- In this IF statement,you have put ' & ' operator which is not logical and.It is bitwise and,so any value except 0x00,will cause to go into IF body I think you should compare your IF result to some specific hex value that you want to get Ex: if ( status & ALTERA_AVALON_UART_CONTROL_RRDY_MSK == 0x..) { temp_read= read_data; } - Altera_Forum
To test if there is data ready to be read I use the following code.
status = IORD_ALTERA_AVALON_UART_STATUS(UART_BASE); if (status & ALTERA_AVALON_UART_CONTROL_RRDY_MSK) { } However, it seems that the if statement is false even when there is data available. Can anyone help?
