JCarr18
7 years agotype mismatch for generic 'integer_values' (Mixed language design)
Hello, I have a mixed-language design where I would like to instantiate a VHDL module in a Verilog file. The module has the following definition: entity vhdl_module is
generic (
integer_values: w...
Vicky1
7 years agoHi Javi,
Please create new System Verilog HDL file & copy& paste the current .v file in to it as below,
File-> New -> System Verilog HDL File.
You can use "Save as.." option & remove the .v file from the project.
module instantiation will be same as Verilog.
Vikas
JCarr18
7 years agoHi @Vicky ,
thanks for your reply. I tried that solution but I got the same error. I guess the conversion I am trying to achieve is not supported so I am thinking about a different solution... How could I pass a single integer from Verilog to a VHDL module? would it be as simplre as for example ".integer_param(5)"? then I could modify my VHDL block to get all the integer parameters separately.
Thanks again,
Javi
