wberbert
7 years agoTX problem on DE2-115
Im having issues with ethernet altera de2-115. I have a design file with NIOS2 and TSE RGMII set using linux as SO from altera linux-sopcfpga. Everything works fine except TX of the ethernet chip. ...
wberbert
7 years agotks
I read this PDF that's why I got so far :)
Is there a way to debug these signals with lite version of quartus?
Other think I notice is that the ENET1_TX_CLK (or zero depending which
ETH you are using) seems not oscislating, because when a use it the output TX led dont blink. It is a pin out of marvell phy.
Tried to supply this clock using pll the tx start blink but no data.
I will try loopback debug, mean while if someone knows anything else Im all ears.
tks.
