10 years agoturning off and on the two 7 segment --- help
hi, I need help with quartus II 9
I should create two verilog files : 1. turn off 2. turn on two 7 segments that display in Altera FPGA's boards I tried some codes in the net but it's not working :( I hope you can help me :(4 Replies
I'm really sorry, I thought it's the right section for my question,
I decide to turn it off and on by using ROM since it's easier, thanks for your concern :) if I face any problem I will come again :) - Altera_Forum
I think you posted this in the wrong section of the forum. It should have been asked in "Coding Questions -> Verilog and System Verilog". Furthermore, we can't help you unless you share the code with us. What FPGA are you using? What dev kit? ~fade - Altera_Forum
--- Quote Start --- Why are you using quartus 9? Quartus is now 15. What is not working? Does it compile? Does it upload? Can you share? --- Quote End --- I know 9 is old and there is newer version, but my college use 9 , so I should use the same one for my project when I googling I found a verilog code that turn off the 7 segment led, but unfortunately when I simulate it shows alot of errors :( - Altera_Forum
