10 years agoturning off and on the two 7 segment --- help
hi, I need help with quartus II 9 I should create two verilog files : 1. turn off 2. turn on two 7 segments that display in Altera FPGA's boards I tried some codes in the net but...
10 years agoHi,
I think you posted this in the wrong section of the forum. It should have been asked in "Coding Questions -> Verilog and System Verilog". Furthermore, we can't help you unless you share the code with us. What FPGA are you using? What dev kit? ~fade
