10 years agoturning off and on the two 7 segment --- help
hi, I need help with quartus II 9 I should create two verilog files : 1. turn off 2. turn on two 7 segments that display in Altera FPGA's boards I tried some codes in the net but...
10 years ago --- Quote Start --- Why are you using quartus 9? Quartus is now 15. What is not working? Does it compile? Does it upload? Can you share? --- Quote End --- I know 9 is old and there is newer version, but my college use 9 , so I should use the same one for my project when I googling I found a verilog code that turn off the 7 segment led, but unfortunately when I simulate it shows alot of errors :(
