TSE phy-less is not possible ??
- 6 years ago
Phy-less is possible.
This is what we I did to solve this issue:
1. In software: seems that internich can output network even if it
detects any phy , yet we forced in getPhySpeed routine to configure
the TSE controller to 1000 (the default in interniche code is 100, so
we had to change it)
2. switch is used in "unmanaged mode", i.e. it is enabled and
configured "automatically" with default configuration (marvell
default) on power.
Yet, The actual problem was with RGMII delay (clock need to be phased
shift from data, this could be solved by adding delay in fpga or in
switch. We solved it by configuring the marvell switch rx delay bit
(it is called"rx" in switch but it is actually the tx from fpga -
through switch - to the output network).
Now everything works !
Thank you very much ,
Ran
If you are using the RGMII mode, your MAC is expecting a clock to come from the phy. If you dont have a phy, then you should use MII.
