14 years agoTSE_MAC Timing Contraints
I have moved (re-posted) this topic in the IP forum. Link below
http://www.alteraforum.com/forum/showthread.php?p=133368#post133368 Hi Guys, I'm using 2x DE2-115s with my own Ethernet design (RGMII) and i'm suspecting i'm getting timing issues. I have no real idea on how to set up constraints and i'm just trying to patch something together and i need some help. what i think i have figured out so far....... I have two primary sources for my info: - The tse_mac manual (attached a screenshot of relavant page to post) - The DE2-115 webserver example Now the Webserver example doesn't include the TSE_MAC timing constrains sdc file. It includes its own SDC file which has the lines:
create_clock -period 8 -name "ENET0_RX_CLK"
set_input_delay -clock "ENET0_RX_CLK" -min 2
For its interface signals to the FPGA pins on the top level it has this below. (MY DESIGN USES THESE ASWELL): //////////// Ethernet 0 //////////
ENET0_GTX_CLK,
ENET0_INT_N,
ENET0_LINK100,
ENET0_MDC,
ENET0_MDIO,
ENET0_RST_N,
ENET0_RX_CLK,
ENET0_RX_COL,
ENET0_RX_CRS,
ENET0_RX_DATA,
ENET0_RX_DV,
ENET0_RX_ER,
ENET0_TX_CLK,
ENET0_TX_DATA,
ENET0_TX_EN,
ENET0_TX_ER,
ENETCLK_25, The TSE manual (page 28, see attached screenie) on the other hand discusses the generated sdc file and how you have to rename signals. The default being: # *************************************************************# Customer modifiable constraints, value is set default by constraints# *************************************************************# Hierarchical path to the TSE
set SYSTEM_PATH_PREFIX ""# Frequency of network-side interface clocks or reference clocks
set TSE_CLOCK_FREQUENCY "125 MHz"# Frequency of FIFO data interface clocks
set FIFO_CLOCK_FREQUENCY "100 MHz"# Frequency of control and status interface clock
set DEFAULT_SYSTEM_CLOCK_SPEED "66 MHz" # Name the clocks that will be coming into the tse core named changed from top level
set TX_CLK "tx_clk"
set RX_CLK "rx_clk"
set CLK "clk"
set FF_TX_CLK "ff_tx_clk"
set FF_RX_CLK "ff_rx_clk"
set TBI_TX_CLK "tbi_tx_clk"
set TBI_RX_CLK "tbi_rx_clk"
set REF_CLK "ref_clk"
I need help to set mine up correctly. Below is the details of my design we many need to know. ------------------------------------------------------------------------------------------- I am feeding my TSE_MAC with botha firmware data path and a Nios datapath through MUX and DeMUX My Nios is running at 100Mhz. As pictured my TSE_MAC is running all 3 clocks at 50MHz. so what exactly do i do here? From what i can gather i imagine i have to (please correct me if wrong)- I would have to change the generated SDC file to have 50Mhz for each of the clocks? all 3?
- Rename the tx and rx clocks to have "ENET0_" prefix to match my top level signals.
- what about the other signals in that sdc?
- Do i then run the TCL? i think i did this and it overwrote my changes to the sdc.
- Add this sdc file to my timing constraints files in the assignment editor.
- Compile?
- Do i need to include the other auto generated TCL files that seem to be generated by SOPC. There is one with my SOPC design name.
- Notice the terasic design doesn't use any of this. Is it a case of theres being a short cut and i shouldn't do both its method and the TSE manual one? or both?
