16 years agoTrue Dual Port Ram Synthesizes error with two clock signals
Hello, well i made a vhdl based, true dual port ram, and i wanted to use two separate clock input for each port, but QuatusII don't synthesizes it and generates the following error Error: ...
16 years ago1. There is nothing specially about putting a design into an FPGA. It doesnt just "flash a ram", the entire chip is saved in flash. The problem here is probably down to your logic inside the FPGA.
2. I tried compiling you code, I got this error: info: ram logic "ram" is uninferred due to inappropriate ram size Plus you also have a chip select. There is no chip select in the HDL template provided by quartus. If you remove the chip select lines it compiles fine. memories inside the cyclone (and every other FPGA) do not have chip select. It will be up to you to modify your other logic to behave correctly.
