15 years agotrouble while using two video source with DE2-70 board
hi! i am working for a project with DE2-70 board. i need two video input and one video output for my project want to switch video sources and also display two video frame by frame on the same scre...
15 years agoIn addition to this, i am trying to use SignalTap II logic analyzer tool. to observe the signals.
In signalTap II logic analyzer settings, when i set iTD1_CLK27 as clock, the video from the first video source is working perfectly, but the second one is not. When i set iTD2_CLK27 as clock for SignalTap II settings, this time the video from coming from the second video source is working perfectly, but the first one is not. I thought that, there is a timing problem in my design. Because There is no change in my code, by only changing Signal Tap II settings, the expected result can be changed. i just want to see both of video coming from the two source by switching between them. Any idea will be very usefull for me. THanks...
