14 years agoTristate performance degradation in Qsys
I migrated from SOPC Builder to Qsys, but this step reduced the overall system performance. I discovered that the Qsys tristate connection (tristate bridge + tristate pin sharer + generic tristate controller) is slower than the SOPC tristate bridge (see the waveform), so it introduces a longer read/write latency with my external memory (which obviously decrease the system performance). After that I try to optimase the performance of Qsys tristate connection, but without success (it is still slower than the SOPC). :mad: The SOPC settings are: - incoming signals are registered - setup time: 30ns - read wait: 30ns - write wait: 30ns - hold time: 0ns - read latency for pipelined transfers: 0 - active chipselect trough readlatency: deselected - max pending read transactions: 0 The Qsys settings are: - setup time: 30ns - read wait: 30ns - write wait: 30ns - hold time: 0ns - max pending read transations: 1 (0 is not allowed) - Turnaround time: 0 - read latency: 1 (if read latency is set to 0, the read result is corrupted) - active chipselect trough readlatency: deselected Has anyone run into the same problem? Best regards. MicioNo RepliesBe the first to reply
