8 years agotriple-speed internet and RTL8211
I use a three-speed Ethernet connection RTL8211 Ethernet module. In NIOS2 software, the serial port returns:Warning :MAC Group[0] -Number of PHY connected is not equal to the number of channel ,Number of PHY :2,channel :1.
Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Static IP Address is 192.168.1.1 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x00003000 INFO : PHY RTL8211 found at PHY address 0x00 of MAC Group[0] INFO : PHY[0.0] - Explicitly mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset INFO : PHY RTL8211 found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset WARNING : MAC Group[0] - Number of PHY connected is not equal to the number of channel, Number of PHY : 2, Channel : 1 INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 1000, Duplex = Full OK, x=16, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x0400020b [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.1 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4)No RepliesBe the first to reply
