16 years agoTrigger signal delay issue need your help
Hello Dears: I have a question need your help. I used 1 EPM7512AETC144-12 device. There are 32 triggers input to it. My task is to use these 512 MAROCELLs to implement delay for each tri...
16 years agoHi mux:
Thanks for your reply! You konw the signal speed is slower than 10Mhz. The problem is that there are 32 trigger signals, and there are not enough registers to buffer them. And the pulse width is about 50 ns, so the sample clock must faster than 40Mhz. Another question is that i need the front edge for some timing fucntions, so the clock will not be too slow.
