11 years agoTransferring USB port data to DE2-115 (GPIO or any other method)
Hi all, Thanks in advance for your time. We have a Picoscope (Digital flexible resolution usb oscilloscope) with USB output for connection to the PC and showing the waveform in Picoscope software....
11 years agoThis isn't going to be possible. As a_x_h_75 said you would need details on the picoscope's data stream which they won't tell you. Even if you get that, I doubt the low performance 1362 USB chip on the DE2-115 could keep up with a picoscope. Nothing's wrong with the 1362, but it is optimized for low power and low pin count operation, not high performance.
If that isn't enough, it would take several months FTE to get the software written/debugged.
