14 years agoTransceiver Toolkit Design Example
Hi, I've recently purchased a Stratix V GX Transceiver Signal Integrity Development Kit and I want to use it to transmit and receive data at 10 Gbps so I can study how our optical circuit affects the...
14 years ago --- Quote Start --- The board I was thinking about getting was the Stratix V transceiver dev kit ( altera.com/products/devkits/altera/kit-transceiver-si-stratix-v.html ). Is this what you were suggesting too? --- Quote End --- There are three Stratix V kits, two have web pages, and the one I was recommending does not. Go to the Stratix V handbook page, and look down the bottom under development kits: http://www.altera.com/literature/lit-stratix-v.jsp You'll see links there. There is the SI kit, the 100G kit, and the Stratix V GX Development kit (the one I was recommending). I have the Stratix IV GX Development kit. There are also kits for the Stratix IV GT FPGAs. --- Quote Start --- Thanks for the advice on differential->single-ended conversion. Suppose I'm given the p and n SMA outputs on a dev board, what do you think is the easiest way to appropriately terminate the n output? e.g. does there exist some pre-made conversion board that I can buy, or will I need to make my own little PCB with the appropriate matching network? --- Quote End --- I haven't seen anything pre-made. You'll have to make something up. Cheers, Dave
