14 years agoTransceiver Toolkit Design Example
Hi, I've recently purchased a Stratix V GX Transceiver Signal Integrity Development Kit and I want to use it to transmit and receive data at 10 Gbps so I can study how our optical circuit affects the...
14 years agoHi Peter,
--- Quote Start --- I am interested in making a device that outputs multiple channels of test patterns over SMA (single-ended, into 50 Ohm loads) at 10 Gbps or faster. --- Quote End --- The code for generating arbitrary PRBS/LFSRs in parallel-mode in the fabric for being serialized in the transmitters is here: http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/lfsr_tutorial.pdf) http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/lfsr_tutorial_src.zip) I need to finish writing the transmitter section in the tutorial, however, the code is there. --- Quote Start --- Since the dev board has 7x channels wired to SMA (7x transmit, 7x receive, all of them diff pairs), I think I should be able to make at least 6 channels output in sync. (The overall goal is to make a "poor man's 0 Gbps multichannel arbitrary pattern generator".) --- Quote End --- The Stratix V GX Development Kit might be a better option. Samtec have HSMC-to-SMA and PCIe-to-SMA breakout cables. Those cables let you access many more transceiver channels. --- Quote Start --- What is your opinion on how likely I am to be able to get reasonable waveforms out of the SMAs if I terminate one of the differential outputs, and transmit only single-ended signals? --- Quote End --- I've done it before for LVDS, look at page 60: http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf) Its not just a matter of simply terminating the signal with a resistor. You have to terminate it into the right kind of network. In the case of the network on p60, to the LVDS driver, it looks like a 100-Ohm load. To the RF input, it looks like a 50-ohm source. You can do the same for the transmitters. Cheers, Dave
