altera33
7 years agoTransceiver scripting API can't open service
Hello, To the customer service, important note : "pls read this message and try to understand the problem." Wiki contains a standard example design "cv_GX_1ch_40b_3125mbps" that can be used to test...
altera33
7 years agoHi,
yes, i asked my colleagues to open a support case. Can you add me to this case and make the diccussion visible for me? Otherwise, my colleagues need to forward every your message to me.
Thanks in advance
CheepinC_altera
7 years agoHi,
Based on my understanding, I am unable to add you to the case due to privacy purpose. If I understand it correctly, only the filer of the IPS case can add others into the visibility. You may try to ask your colleagues to see if he/she is able to add you in?
Thank you.
Chee Pin
