altera33
7 years agoTransceiver scripting API can't open service
Hello, To the customer service, important note : "pls read this message and try to understand the problem." Wiki contains a standard example design "cv_GX_1ch_40b_3125mbps" that can be used to test...
CheepinC_altera
7 years agoHi,
As I understand it, there is currently an IPS case 440018 on this which I believe is filed by your team. Not sure if you have had visibility to the IPS case. There have been discussion on-going in the IPS case. It would be great if you could refer to it.
Please feel free to let me know if this is a different inquiry from the IPS case.
Thank you.
