SK_VA
6 years agoTransceiver Qsys generation through script
How to generate transceiver PHY IP through script without using GUI? Is there any option to configure the transceiverdata rate and phy pll output frequency through qsf changes or script without open...
CheepinC_altera
6 years agoThanks for your update and sharing. Glad to hear that you have managed to achieve that. Should you encounter any issue when using the command, you may use the workaround of using IP Catalog. Thank you.
