11 years agoTransceiver PCS Question
When implementing GIGE on CycloneV transceiver using Custom Phy is needed to perform "running disparity rules" on FPGA logic outside transceiver phy? I think the answer is yes, but I would to c...
11 years agoThank you kkaibara this helps me a lot.
I will run this test pattern when I write sync state machine. ;-) cheers!
