11 years agoTransceiver PCS Question
When implementing GIGE on CycloneV transceiver using Custom Phy is needed to perform "running disparity rules" on FPGA logic outside transceiver phy? I think the answer is yes, but I would to c...
11 years agoOk, so I need to transmit control codes on the line and check if extra /R/ is need based on even/odd packet but PCS will check running disparity to perform 8b/10b job.
e.g., I'm on sync phase and want to transmit data 8'hAA. I will send a /S/ 8'hAA /T/R/R ((tx_paralleldata = 40'hFBAAFDD7D7 ) , tx_datak = 5'b10111)) and then check if rx_disperr still no error. It is correct? Cheers! ps. I'm not planning auto negotiation for now :)
