11 years agoTransceiver PCS Question
When implementing GIGE on CycloneV transceiver using Custom Phy is needed to perform "running disparity rules" on FPGA logic outside transceiver phy? I think the answer is yes, but I would to c...
11 years agoYes. If you transmit even length packet, the FCS must be followed by /T/R/ (tx_paralleldata = 16'hFDF7, tx_datak = 2'b11). If you transmit odd length frames, the FCS must be followed by /T/R/R/ (tx_paralleldata = 24'hFDF7F7, tx_datak = 3'b111).
BTW, the GIGE mode is tricky. You should go through AN537 if you plan to use 1000BASE-X/SGMII Auto-Negotiation. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an537.pdf
