11 years agoTransceiver PCS Question
When implementing GIGE on CycloneV transceiver using Custom Phy is needed to perform "running disparity rules" on FPGA logic outside transceiver phy? I think the answer is yes, but I would to c...
11 years agoAre you referring to running disparity checking? If I remember it correct the Custom PHY has this function available where it will flag error when running disparity is incorrect. The output status port is rx_disperr.
