frycoo's avatar
frycoo
6 years ago
Transceiver native PHY Cyclone 10 gx, 7:1 serialization factor
Hello.
Is it posible to use Transceiver Native PHY for Cyclone 10 GX as a transmitter with 7:1 serialization factor (i. e. for Camera Link output)? Can anyone give me a hint on how to configure it? I'm trying to use high speed serializers as I'm out of standard serializers due to huge serial data input and sdram driver.
  • frycoo's avatar
    frycoo
    Thanks for your reply. It was very helpful. Now I found that the Intel® Cyclone® 10 GX Transceiver PHY User Guide chapter 5.1.1.1. clearly states that 8, 10, 16, 20, 32, 40, and 64 are only supported serialization factors.
    Nevertheless it seems to be possible to "deserialize" 7 bit vector into 8 bit vector as you suggested.
  • CheepinC_altera's avatar
    CheepinC_altera
    As I understand it, you are inquiring about 7:1 serialization factor using Native PHY. For your information, this is not something supported by the Native PHY. Sorry for the inconvenience.
    Not sure if this is something feasible, just some idea, probably you can explore into coding some adapter to convert your 7 bits parallel to the support data width ie 8 before feeding into Native PHY.
    Thank you.
