Tranceiver PHY or pll fitting error!
- 3 years ago
hi Sung
Thanks for the update.
Glad to see that the issue was resolved.
Hi Sir
I can't compile the design further due to errors below, looks like absolute path are being used in your design.
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File D:/EPI_TX/DISPLAY_99232_341_682_WITH_ADC_EPI_211116/src/vector_rom/vector_htol.hex for ROM instance u0_epi_data|u_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File D:/EPI_TX/DISPLAY_99232_341_682_WITH_ADC_EPI_211116/src/lock_rom/lock_rom.hex for ROM instance u0_epi_data|u_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom1/IPS_AEQ_CT_ILT_1Line.mif for ROM instance u1_epi_data|u1_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom1/TTL.mif for ROM instance u1_epi_data|u1_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom2/Make_1th_2th-data.mif for ROM instance u2_epi_data|u2_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom2/TTL_193674.mif for ROM instance u2_epi_data|u2_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom3/Make_1th_2th-data.mif for ROM instance u3_epi_data|u3_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom3/TTL_193674.mif for ROM instance u3_epi_data|u3_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom4/Make_1th_2th-data.mif for ROM instance u4_epi_data|u4_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom4/TTL_193674.mif for ROM instance u4_epi_data|u4_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom5/Make_1th_2th-data.mif for ROM instance u5_epi_data|u5_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom5/TTL_193674.mif for ROM instance u5_epi_data|u5_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom6/Make_1th_2th-data.mif for ROM instance u6_epi_data|u6_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom6/TTL_193674.mif for ROM instance u6_epi_data|u6_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom7/Make_1th_2th-data.mif for ROM instance u7_epi_data|u7_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom7/TTL_193674.mif for ROM instance u7_epi_data|u7_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom8/Make_1th_2th-data.mif for ROM instance u8_epi_data|u8_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom8/TTL_193674.mif for ROM instance u8_epi_data|u8_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom9/Make_1th_2th-data.mif for ROM instance u9_epi_data|u9_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom9/TTL_193674.mif for ROM instance u9_epi_data|u9_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/vector_rom10/Make_1th_2th-data.mif for ROM instance u10_epi_data|u10_vector_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
Error(127001): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File E:/EPI_TX/DISPLAY_1/src/lock_rom10/TTL_193674.mif for ROM instance u10_epi_data|u10_lock_rom|rom_1port_0|altera_syncram_component|auto_generated|altsyncram1|ALTSYNCRAM
- sung_chul3 years ago
Hi skbeh
Yes, of course!
I have written
No Success!
8 fpll + 3 atx pll
Like you said, I used "atx pll", so result Fail
and ..
Where to connect mcgb_serial_clk?
