MEmel1
7 years agoTranceiver based switch
Hi, Is there any way to retransmit data, received by tranceiver, around serialization/deserialization sequence? Basically, I need Serdes 3-port swicth functionality with a strict requirments on pr...
Deshi_Intel
7 years agoHi MEmel1,
Intel FPGA transceiver architecture is designed in a way where user can't bypass PMA block (that contains deserializer). User can only bypass the PCS block after the PMA.
Attached is the high level block diagram for your reference.
You can also find out more from XCVR user guide doc (chapter 5) in below link
dlim
