CosmoKramer's avatar
CosmoKramer
3 years ago
traffic generator without example design
Can I connect traffic generator to emif ip itself instead of using example design?
  • sstrell's avatar
    sstrell
    The TG is a Platform Designer component, so if you're saying you want to connect it to the rest of your design outside of Platform Designer, that's going to be a bit tricky. Adzim thinks it's possible, but I'm not sure it will work.
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi Sandy,
    "However, I should be able copy TG files and move them to correct location and instantiate TG as a module and connect it to emif ip in our source code. right?"
    • Yes you should be able to copy TG and connect to EMIF IP in your design.
    Adzim
  • CosmoKramer's avatar
    CosmoKramer
    Thank you for replying. I understand TG is not ip.
  • sstrell's avatar
    sstrell
    No, you have to create an example design. It's not a standalone IP you can manually add. You could, of course, create the example design and replace everything other than the traffic generator.
