11 years agoTotal I/O sink current per max v I/O bank
Hi, is there any sink current limitation per IO bank in max v device? I only find the sink current per io pin from the data sheet. Thanks for any advice here
11 years agoSince there is no specific spec on the IO bank sink current limitation, I believe this should be already taken care by the sink current per IO pin. As long as you ensure no exceed the limit of each IO pin, the bank should be safe.
