11 years agoTotal execution time and propagation delay
hi, How to calculate total execution time and propagation delay for VHDL files under Quartus II? Thank you
11 years ago --- Quote Start --- What clock speed have you specified in your SDC file? without one, Timequest will check the timing at 1000Mhz (which is much faster than is realistically acheiveable). But it will report the fmax for the circuit (which is the fastest clock speed you could run the design at). --- Quote End --- Thank you Trichky, Using your informations i was able solve problems. Now i have a synchronous adder without errors. So, how to calculate the total execution time of this adder by using "TimeQuest Timing Analyser" ? Best Regards,
