11 years agoTotal execution time and propagation delay
hi, How to calculate total execution time and propagation delay for VHDL files under Quartus II? Thank you
11 years ago --- Quote Start --- The timing analyser will ensure that your design meets the timing specifications that you give it. Assuming you mean latency when you refer to "execution time", then you can easily work this out from the number of registers in the pipeline. --- Quote End --- Hi Tricky, Thank you for your answer. I have, for example, an adder 4 bits and i want to calculate the "hardware execution time" for this adder. After compiling the code, and by using "TimeQuest Timing Analyser", i got the attached "Propagation Delay". Knowing that the total "propagation delay" is taken as the "hardware execution time", how to calculate the total "propagation delay"? In the attached file, i have RR=RF=FF=FR, is it normal?? Best Regards,
